Current DTCs 1-19-08
RuS4ty
- Vehicles: FZJ80/S4/RS4
VAG-COM Version: Release 704.1
Data version: 20071016
Saturday,19,January,2008,14:49:54:39335
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 8D0 907 551 M
Component: 2.7l V6/5VT G01 0002
Coding: 06711
Shop #: WSC 06435
5 Faults Found:
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-10 - - - Intermittent
16544 - Oxygen (Lambda) Sensor B2 S2: No Activity
P0160 - 35-10 - - - Intermittent
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0110 0001
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16204
Shop #: WSC 63351
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
End --------------------------------------------------------------------------------------------------
Coding: 06711
Shop #: WSC 06435
5 Faults Found:
P0154 - 35-00 - -
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
Coding: 16204
Shop #: WSC 63351
4 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
S4 driver
Wow! That's a lot of stuff. When did all that happen?
http://wiki.ross-tech.com/index.php/00955:RuS4ty wrote: 00955 - Key 1
00955 - Key 1: Adaptation Limit Surpassed
Possible Symptoms
* Remote control not working.
Possible Causes
* Key not matched.
* Key operated more than 200 times while out of range.
Possible Solutions
* See vehicle specific page for synchronisation/adaptation procedures.
I like the key operated more than 200 times on the best, personally,
Well it is telling you that the button has been pushed more than 200 times out of range of the car, so rolling code technology can't sync up with the car anymore. But with a stated range of 2 feet, it should be used to it.....
Mill3niumThr33
For the O2 errors, get underneath your car on the passengers side and get a visual on the sensors - trace them back to where they plug into the harness - I would bet they are knocked loose/unpluged or worse. Probably happened on your Hyalite trip...
