I will post a project here with pics and everything.
So here is the rundown so far.
The transmission I am getting has ~100k miles on it, and was fully rebuilt and has only 5000 miles on the rebuild.
Here is a sneak peak of all the stuff it comes with and the mess I am in for
1. Pedal Cluster
2. Shift Box and Cables with selector shaft and connecting hardware
3. Clutch Master cylinder
4. Clutch Slave Cylinder
5. Line between Clutch slave and master
6. Master cylinder mounting bracket, specify abs or non abs
7. Karmann shifter trim plate with OEM boot and shift knob
8. o2a VR6 Transmission with linkage and reverse light sender
9. front motor mount bracket
10. 5 speed starter
And some other stuff like nuts, bolts, lines and what not.
Cost for the swap with above parts- $650
The clutch and flywheel I will have to get in a couple weeks when funds permit it.
