WANTED: 5spd MK4 1.8t O2J Transmission
As title states. Looking for stock 5 speed gearing for my 1.8t
Re: WANTED: 5spd MK4 1.8t Transmission
I have one I inherited - I'd have to get the model # from it, but I think it's from an MKV TDI. Missing 5th gear, and I was told has a slight 2nd-3rd gear grind (typical). Appears to work OK, but needs some TLC. Interested?
Probably pass on that Mike, but thanks! :) Just looking for a turn-key gearbox.
Not sure what I was thinking with the VR gears in the GLI. There is a huge gap between 2nd and 3rd. That, and the cruise works in 1st through 4th but not 5th because its out of an acceptable RPM/VSS to the ECU. I also would like an upgraded differential as power wants to hop between wheels in a straight line at full boost. Takes two hands on the wheel :confused:
Gotcha! Just throwing it out there, we never know what you are up to :)
So if you are looking for a turnkey trans, then you want an 02J? Basically anything out of an MKIV Jetta/Golf/Beetle 1.8T or 2.0 (not VR6 or TDI).
Here's a really good link for VW transmission reference that may help for reference: http://www.zelek.com/diagram_charts/diagramlist.htm
There may be something in one of the Billings junkyards.
itskmill06
In the engine bay...
Post by itskmill06 »
Where ya at? This is hamilton/missoula
http://missoula.craigslist.org/pts/5500459290.html
Great googa mooga. $650
Leifro
Vehicles: 80'VrCaddy
83TCQ-85S1
90Corrado-83GTI
Post by Leifro »
That's not me I swear! I don't even know that guy
Re: WANTED: 5spd MK4 1.8t O2J Transmission
Six fiddy! Good Lawd! I aint give that monsta no god damn Six fiddy!
Mikewire wrote: So if you are looking for a turnkey trans, then you want an 02J? Basically anything out of an MKIV Jetta/Golf/Beetle 1.8T or 2.0 (not VR6 or TDI).
MT-Getto wrote:Looking for stock 5 speed gearing for my 1.8t
Probably should have worded. "Looking for a stock MK4 1.8T o2j Transmission".
I'll have to check out that CL gearbox. My last one came from the junk yard in Billings. Don't think I want to pay much more than a few hundred for a 5speed unless its already got an LSD.
Why not just buy a new one from VW? You should be able to get a new one for around $1500. I dunno, I've been down the crap used transmission road. Ended up costing me more than if I just bought a new one and put an LSD in it.
