Wade and I, plus my kids went up to Bozeman to check out a Caddy for sale and ended up trailering it home:
From the CL ad:
All in all it was a clean truck...no strut tower rust except for a minor amount in the rear passengers tower, pans are good. No brainer, so I made the deal and we rolled it up on my trailer.1982 VW Rabbit Truck. 5 speed. Gas engine. Price includes topper (see photos).
CURRENTLY DOES NOT RUN. Reliable front wheel drive truck for 17 years of regular use. A fantastic truck when it runs. Needs engine work - not sure how extensive. I don't have the time or know-how to work on it. In great shape otherwise - minor surface rust. Interior is in good condition. The perfect project truck for someone with know-how. Offers considered.
Going over the guys story, some things weren't lining up. We were told it ran, it was parked, and the next day it wouldn't turn over, and couldn't be turned over with a wrench...so most likely something internal or a seized motor. We spotted a deep dent in the oil pan, which could be the problem, but it was decided to check it out when we got back to my house. Either way I already had a replacement motor or two I could transplant if needed.
So we got it home and rolled it into my garage and pulled the plugs...they were corroded pretty bad, need replaced. Buttoned up the starter, which was not fully bolted in. Pulled the timing cover...belt is intact and aside from some oil leaking, it looks good. Pulled the plugs...inside of #1 we found a broken off piece of Phillips screwdriver!?!
Then checked timing...checked @ TDC and the marks line up.
Ran to Orellieys and grabbed some plugs and a jug of coolant.
Installed new plugs, and grabbed the battery from the other Caddy. After about a minute of cranking, the motor right started up
Wade made a great video:
