Misfire Cylinder 1 and 3
So, I have an annoying misfire on my dune buggy. Carb is good, no vacuum leaks, has electronic ignition which is timed spot on, valves are spot on, spark is good, new plugs... I keep getting a constant misfire on cylinders 1 and 3. By constant I mean they aren't even firing. It sounds like they pick up when you open up the throttle, but not 100%. It's driving me nuts, so any ideas are greatly appreciated.
Re: Misfire Cylinder 1 and 3
Nope, has a massive oil cooler. Uploading a video.YASHA7FOLD wrote:Did it ever get hot on you?
Just asking because I have a 92 plate cooler on mine and it still needed a fan. But then again it's under the car. Where is yours located ?
Yeah, the cooler has a fan and its mounted away from the engine.
Here is a video
[youtube]http://www.youtube.com/watch?v=hNc7TIWDQ6g[/youtube]
Here is a video
- SweaterVest
- Vehicles: 97' VW GTI VR6
Compression?
Sent from my iPhone using Tapatalk 2
Lost my compression tester, but going to buy one tomorrow. Doubt it would lose compression from sitting over the winter, but you never know.SweaterVest wrote:Compression?
Sounds like carb issues. Have you tuned it lately? And a compression test wouldn't hurt either.
Maybe, but not sure why it would cause just cylinders 1 and 3 to misfire. I'll grab another carb kit though and go through it again.YASHA7FOLD wrote:Sounds like carb issues. Have you tuned it lately? And a compression test wouldn't hurt either.
