Thanks
Jetta problems
- Leifro
- Vehicles: 80'VrCaddy
83TCQ-85S1
90Corrado-83GTI - Location: H-Town Montana
Jetta problems
hey guys i got a 97 jetta 2.0 5 speed. broke a timing belt, but all seems fine with the motor, its the electical im having problems with and they are bad... So this is whats up. ive replaced sensors
ive replaced switches
ive even tried another computer
but still there are parts of my elecrical system not getting power. The knock, and the crank sensor are not getting any hot power. real strange. tested my inputs to the ecu and those are all powered up but isnt getting power out to a couple of those sensors. the car itself had over heated due to bad timing and low colant. got all that fixed even timed the intermediate shaft to its proper place for the tdc sensor which i had wrong but it still has no spark... none. it gives a slight pop when i let it sit for a day then turn it over. so i know its somewhat related to that issue. realays are good even igniton switch is new but still no spark. ugh im lost with this green jetta, i wanna say its too new for me to wrench with but that would be silly of me to assume so someone help bounce some ideas back and forth, could it be my ecu? it seems strange that an ecu would just fry half of itself. Also, when i turn the key on the temp rises half way even though its cold, with the key on i have tried disconecting all sensors but the only way i can get that temp gauge to drop back to zero is if i unscrew the whole motor harness plug from its sorce there on the block. Could it just be my cumputer or is there a hidden underlying problem i am unaware of. Any help would be great guys please dont leave me hangin here i wanna retain local knowlage without having to post on vortex, there is way too many unfinished threads ive found that dont help a whole lot
Thanks
Thanks
Re: Jetta problems
Check all your ground connections and see if any are corroded.
TDI in MT
- Vehicles: 07 Honda Accord
Re: Jetta problems
I'm with Yasha on the grounds. A Dremel with a wire brush is ideal for cleaning them up.
- Leifro
83TCQ-85S1
Re: Jetta problems
tested my grounds. and that is a good starting point. i removed the battery tray and made the double grounding point one ground. took a test light from the positive and checked the motor, hood, intake, tranz, rain tray, exhaust manifold, grounds to all my sensor connections and to my computer, also under the dash then the fuse panle then the door panle and even my steering wheel. oh also tested my grounds at the trunk lid. Now, Grounding is only nesicaary for something to electric right so where is it you sujest i check for grounding? That is a reeeeaaalllly Broooood statement with grounding cause the whole car is grounded.... so ex, like check for grounding on the two bolts that hold on the ecm, for example. which something simple as a ground id feel kinda silly missing twice but maybe a sujestive spot ?
Re: Jetta problems
Get a Bently it will show you were all the ground points are
- Leifro
83TCQ-85S1
Re: Jetta problems
For sure. I like buying books. Will have to order one. Does Missoula Posses any at their vw dealerships?
Re: Jetta problems
sounds of possible corrosion in fuse box or in main engine harness connector. check the ecu relay as well. have you done a comp check?
- SweaterVest
- Vehicles: 97' VW GTI VR6
Re: Jetta problems
We no longer have a dealership.
- Leifro
83TCQ-85S1
Re: Jetta problems
Thank you for the update sweater vest. I was unaware of this unforchante news.
I will perform a compression test this afternoon. Could have blown a head gasket when it over heated.
- Leifro
83TCQ-85S1
Re: Jetta problems
This turned out to be a bad head gasket. No compression was the culprit
