VR6 Turbo Part-out & new spares ... BBS, Recaro, Schimmel +
DieGTi
In the engine bay...
Post by DieGTi »
Hello guys - making some changes with the herd and have quite a few items that need to go. I'm located in NH now but will ship anything listed here at true cost or I can carry on one of my trips to Billings/Bozeman that I make a couple times a year. BSE take 10% off the list price... I have a few local takers on the shell already.
Lots of parts including duplicates and spares. Everything with a * is available immediately. Check the list; I won't break the car up until more than $3000 in parts are claimed. You can buy the whole car for $8800 without any of the extras. Everything marked with a " * " is an extra. Combo up items for deals.
Schimmel Short Runner Intake w/fuel rail - $1000
60lbs Siemens Deka Injectors, 6 count - $250
FrozenBoost 1200HP Air to water Intercooler/heat exhanger with pipe to receive 50mm Tial BOV. Includes Bosch Cobra pump, largest heat exchanger, inline filler neck and lines. Provisioning for mounts on bottom and bends to fit mk2/mk3 ATP type with Schimmel short runner. $725
OBD1 VR6 12v AAA Tallblock with Autotech 262 cams, new rod bearings, new piston rings, ARP main studs, ARP rod bolts, ARP head studs, VWTurbo.de 9:1 spacer, Custom heat-sink valve cover. Recent chains/guides. Hear it run - makes good power still. $1500
MS2 Standalone ECU/custom CE2 engine harness for mk3 vr6 instruments. This is plug and play. Will include tuning cable. 400KPA map sensor installed; for use with OEM Coolant and air temp sensors and dumb coils. File loaded for 60lbs injector vr6. Bubble face 140mph vr6 instruments with orange needles and green LED illumination. MFA shows 99.9MPG otherwise all works. $1300.
VR6 CCM Transmission; new seals 15k ago. All shifts smooth, missing chunk from bell housing bottom that doesn't change how it works. $250.
OEM VW VR6 starter for above transmission. Works great. $75
Clutchnet 6-puck spring clutch w/stock pressure plate and flywheel/ring gear. $100
Aftermarket VR6 Starter, short snout - brand new in box. $75* SALE PENDING
VR6 CCM Transmission; new cup seals, input shaft seal removed. Peloquin limited slip differential with ARP ring gear bolts (installed by Gary), TDI 5th gear set, billet pinion cuff, Gruvenparts stainless short shifter. High temp black paint. $1500*
Vr6 AC Compressor, Passat Lines (perfect for mk2 around strut tower) and mk3 condensor/receiver dryer/expansion valve and passat HVAC box/evaporator. Great shape... blew ice cold. $250
Spearco Intercooler & Greddy BOV, large front mount with flanges for mk2 lower rad support offset. 2.5" in/out. Includes stainless 2.5" piping used on mk2 vr6; needs 1" straight section to be used again with stock intake manifold. $225 ***sold***
4" K&N filter, barely used. $30*
ATP 3" stainless downpipe, T4 4 bolt flange, bung for EGT, 02 sensor. Great shape, wrapped. $250.
Tial 35MM External Wastegate, used 40k miles. Includes good fire ring and dump tube but no barbs/fittings. $100*
3" mild steel turbo-back exhaust with hangers. Catco hi-flow catalyst, Summit racing glasspack muffler in tunnel, FlowMaster 70 Series Bigblock II rear muffler. Welds aren't that pretty but they're solid. Quiet when you want it, loud when it's time for business. $300
Godspeed Aluminum Corrado Radiator w/Gruven Parts aluminum elbow and Jegs fans. Will include 160F fan switch and thermostat in housing. $275.
Clutchnet Red PP & 6 puck sprung disc. Brand new in box, C1364 if I recall correctly. $350*
AASCO 5.6Lbs Vr6 aluminum Flywheel, Brand new in box. $275*
BBS RM 15" with center caps and decent lips (removed). $1000*
OBD1 EIP Eprom with full engine harness. $150*
Cartech Fuel Management Unit aka rising rate fuel pressure regulator. $100*
1990 German Jetta GL chassis. Rustoleum smoke grey paint and big bumpers. Desert southwest/salt free since 2005. MK3 Vr6 subframe, Corrado G60 brakes all around, SLC corrado front lower subframe, vr6 shifter cables and pedal cluster, Blackforest industries stg1 green mounts all around, g60 trans mount. Decent shape but could use new undercoat due to light surface rust where undercoat was removed. Herculiner Truck liner on lower 1/3 of doors/rockers/fenders. Has grey carpet, black headliner, dash and plastics. Will roll on the Fitipaldi 2pc wheels ready for the swap of your choice; $1300
GLI grey power recaro seats front and rear. Average shape; netting on bottom of drivers seat needs replacement. Will include power window door cards in below average condition. $400
Momo steering wheel with Wolfsburg badge horn button and hub for late MK2 (large spline) and leather shift boot with red stitching. $125
Innovate LMA-2 Wideband O2 sensor, programmable outputs with autometer dummy gauge, used but comes with original box and documentation - $200
42 Draft Designs mk2 triple gauge panel - $40
VDO Boost, 25lbs with vacuum as well - $25
VDO EGT, slow swing sensor - $80
VR6 German Lower lip spoiler, new in packaging - $60*
MK2 GLi Foam rubber trunk lid spoiler $90
I'm sure there is more I'm forgetting... I'll add to the list in futures posts to this topic. PM would work best for interest.
:smoke:
DieGTi
Re: VR6 Turbo Part-out & new spares ... BBS, Recaro, Schimmel +
Post by DieGTi »
Bump!
PICS of the RM's?
DieGTi
Post by DieGTi »
I'll get better shots the next time I'm up there with my real camera... these are from the cell phone.
They basically need a good cleaning/polishing. If you're looking for a wheel to show then you would want to have the centers powdercoated, new lips/bolts etc of course.
Pm'd ya bout exhaust few days ago. No response.
Let me kick around the RM's for a few days, ill hit you up.
DieGTi
Post by DieGTi »
Exhaust would be a bit more to ship... I'd have to chop it into a few pieces which would reduce the value to you I imagine. I would be shipping from 03103.
Wheels - LMK if you want more pics. I don't have anyone hot on them at the moment. They're in decent shape but not minty fresh. Three are disassembled so I could box them all together to save on shipping.
DieGTi
Post by DieGTi »
RM's sold but still have a complete driving car that I'm thinking about selling.
The MK2 VRT?
DieGTi
Post by DieGTi »
Yeah... thinking selling without parting would be best. Something inside keeps telling me to put the long-legged TDI 5th gear trans in to see where the top speed is. :)
