A/C
A/C
I've been driving the Jetta a bit and noticed that the A/C will not shut off, even when the button is off. Cold air, not outside air is blowing all the time. I can disconnect the compressor, but that's no good. No codes when I scan it.
What would cause the A/C to stick ON?
Re: A/C
its more than likely something electrical. The switch could actually be stuck/broke and just show it is off when it is still on.
A/C
Or is there a relay that could be stuck
Re: A/C
YASHA7FOLD wrote:Or is there a relay that could be stuck
I don't think the compressor has a relay for it.
Re: A/C
I did replace the #53 relay, didn't make a difference. Thing is, when I hit the AC switch I hear the fans kick on and it's still pumping cold air.
Maybe something with the hi/lo pressure?
choptopvolksrod
Re: A/C
Post by choptopvolksrod »
maybe the clutch is stuck in the enguaged position. would make sense if it still blows cold when you unplug it.
Re: A/C
choptopvolksrod wrote:maybe the clutch is stuck in the enguaged position. would make sense if it still blows cold when you unplug it.
Could be this. So how would I "unstick" it?
choptopvolksrod
Re: A/C
well first you would remove the compressor then find the nearest waste recepticle and place the a/c compressor in it and install a new one hahaha. just kidding i imagine you can dissasemble the clutch and check for debris and stuff.
squabeggs
Re: A/C
Post by squabeggs »
Thought I ran across something about this on TDIclub while researching my radiator fans.
It does sound like a stuck compressor clutch, I'll see if I can find the link that I thought I read...helpful, I know.
Bags are for groceries.
squabeggs
Re: A/C
Post by squabeggs »
Dont know if this will be of any help
http://www.myturbodiesel.com/forum/f5/c ... oval-8010/
