Workflow:
- Parts needed:
- 01A 5 sp. transmission with B6 tailpiece
- Valeo HD clutch and SMFW
- Pilot bearing from an Audi 2.8L V6
- Manual trans drive shaft
- Manual rear diff
- Manual pedal cluster w/ clutch switch
- Master cylinder
- Slave cylinder
- Brake res. -> master cylinder soft line
- Master cly. -> slave cly. hard line
- Manual downpipe
- Drop exhaust
- Pull trans, rear diff, front axles and drive line
- Remove auto pedal cluster
- Install pilot bearing
- Install clutch
- Install shift housing
- Install transmission
- Install pedal cluster
- Wire up clutch switch etc.
- Fluid into front diff, trans, center and rear diff
- Bleed brakes and clutch
- Re-install the driveline and torque to spec
- Reprogram ABS, ECU and cluster w/ VCDS
- Drive and redjust, etc. as needed
