I'm trying to get my new project coupe going and I think my ecu is not grounding out the injectors, keeping them shut at all times. The damn thing runs nicely off starter fluid and the spark is there so...anyone have a spare ecu that I could try? Not really sure what happened, but I guess it had something to do with leaving a ground off the starting circuit...the details are fuzzy... but I want to drive this thing! Let me know if you can help me out! Thanks again guys,
Richie
Another digi II ecu in need!
Re: Another digi II ecu in need!
If there are any grounds loose at any point, or insufficient grounds, the injector drive in the ecu will fail. check and clean all grounds before trying another ecu!
- Spoolin!
- Vehicles: subi's and vdubs
i have a spare triumph-adler digi2 ecu....
Hey thanks for the insight Brandon. I know how important those grounds can be (owning an old-ass-audi) and will take care of those before I try another, good call. If nothing still works then I'll be getting a hold of you t53a. Cheers
- choncho
- In the engine bay...
- Vehicles: jettas n a 3/4ton
i got one in the attic. Supposively it's from a jetta 16v. But I never played with it. Yours if you want it
awesome Kevin, thanks! I'll let you know if I need one.
