FS: Project Baja Beetle
2000 NewBeetle 155.5K 5spd 2.0
Hate to let you all down, but I need space in my drive way and should be focusing on my other projects.
Asking $650 or $500 minus the gearbox/shifter.
To me this is a parts car but could make a great beater.
Good:
-Just did the head-gasket and coolant distribution flange to see if it runs.
Runs and drives well.
-New fuel pump
Bad:
-Thrashed Body and Interior.
The interior could probably be saved. Its not damaged or torn, just really really dirty.
-Radiator is Toast.
Core support damaged. Hole in bottom of radiator. New one =<$150
http://www.germanautoparts.com/Volkswag ... ling/168/2
-Needs tune up.
Probably just plugs and wires.
-Timing belt looks tired.
-Instrument cluster is messed up.
I'm sure there are many things I am missing as I have only had this long enough to get it running again. I will try to get more photos this evening.
Re: FS: Project Baja Beetle
Trev, does it have cruise? Whats up with the cluster? The rest looks OK. I think that rear fender can be replaced easily.
Oh, wait, are you keeping the 02J(?) and shift assembly?
MikeWire wrote:Trev, does it have cruise? Whats up with the cluster? The rest looks OK. I think that rear fender can be replaced easily.
I will check on the cruise. If someone wants to part this, I'd like to buy the trans back but don't really need it.
Sale Pending
SOLD
