No big deal, I can handle some body damage. As long as it still drives, I can live with it. But just a few weeks later, I get hit in the parking lot where I work which becomes the reason why I have this picture :
Again, nothing I can't handle. So axle gets replaced, drives all sorts of lovely and doing just fine. Climb the on ramp to go to the far side of town and what happens? RPM's climb, speed doesn't. *#$!ing clutch. So she gets parked and sits for a 7-8 months. Until I finally get in a position where I can do what needs to be done. That's right, build the damn thing!
And this is how it sits at the moment. It's getting thrown on a trailer and moved to a friend's shop so I can pull the motor and install the clutch, re-do the exhaust, and finish with all the other maintenance things.
List of parts being installed at the moment :
APR Snub Mount
APR Turbo Inlet Pipe
Test Pipe
Timing belt kit
Valeo Clutch with Single Mass Flywheel (rated to 275lb-ft of tq)
Boost gauge
K03s Turbo (brand new)
Round two will include :
Integrated Engineering rods
JE Pistons (82mm)
Full tear down of motor and replacing all bearings, seals, gaskets
Stronger clutch (still undecided, as I haven't decided what turbo I'm going with)
Rounds three :
Power!
