Then I cleaned the wheel using water and a fine scotchbrite.
I then applied the first coat of dye...be sure to wear gloves
then next coat
and repeat
after several more coats of dye I was happy
Then the sealer or tan kote as it is called
I did several coats of this as well..I didn't coat as well as the dye and looked like it was almost repelled by the dye but I used a soft cloth to smooth out each coat. Eventually I got this.
and re-installed
