WTB: 12V VR6 shortblock
Well my Corrado needs a new block. All the bores have a pretty good lip around them about half way up that I can catch a finger nail on.
Anyone have a low mileage 12v shortblock?
Re: WTB: 12V VR6 shortblock
What, no compression test?! I keed.
that doesn't help. Do you know of anyone with a block?MikeWire wrote:What, no compression test?! I keed.
To get the requirements out on what you want, how low is 'low mileage'? Do you want a rebuild-able core or a ready to build? How about a pulled running motor?
I ask because there's a 12v VR6 Passat at the yard here I was planning on getting a 5 speed from, and maybe the block is OK, but I have no details - Google A1 Johnson's in Billings.
I am wondering why you did a redneck compression test on a perfectly running good motor, instead of performing a proper test. But maybe I'm wrong and you did, I dunno. Not trying to pry, just wondering what your plans are.
^ THIS, and or make a 3.0 litre if the lip is that big, rods should be good to go, and upgrade the piston to suit the boost.
There's no one in Montana that does it.MT-Getto wrote:Bore to 2.9
Think outside the (montana shaped) box
Maybe Ben will chime in here.
the machinist in bozeman isnt "set-up" to do it, but assures us he can, hell measure it out on his sunnen bore machine so he has the future capability too.
I think i'm going to slap it back together and run it till it blows.
