140K
Purrs like a chicken
Complete swap means from the fuel pump to the downpipe and everything in between.
Installed TT cams, new lifters, chains, water pump last winter. Less than 20k on the timing belt. I would like to bundle the entire fuel system with this motor, including the TT custom chipped Motronic ECU and complete wire harness. This would be plug and play for any CE2 car.
This motor does leak oil but seals are cheap and easy to install with the motor removed.
I gave TT a little over $600 for the gofast parts. Shoot an offer!
