Picked up the GTI
Picked up the GTI
Well it was a great day yesterday. I finally picked up the GtI from Checkers. Although the trip home was a little bit on the butt pucker side. We hit some bad weather and went sideways with the truck 3 times and between those a deer decided to jump out in front of us. Thanks God we didn't hit it. All is good the car is now in my shop and if you have any MK1 parts that you don't need let me know. Laters
- Checkers
Re: Picked up the GTI
The roads were hella gnar yesterday! I'm going to get the title squared away today and I'll be on the hunt for a hood and more parts for you!
Thanks for everything man and also tell Brandon thanks for me. What was Brandon's name on the forum again?
- Checkers
Brandon is kompressorgolf
not a problem, glad to see it going to a good home, ill see about rounding up more parts for you as well. good luck and post alot of pics!
Pre-Checkers pics
Glad to see it going to a home, whats the plan for power?
BOOST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! LOL
Thanks for the pics. That is awesome. It is definitely going to look a little different than those pics down the road.And yes BOOST!
^ again, the G60 was already an 8.0-1 CR engine, a 16v head will drop that to about 6-6.5-1 CR youll need to find a piston, that can get the ratio back to 8 or 8.5-1 for ideal boost ratios. or simply use a stock ABA bottom end. if you use the ABA bottom end, youll need the 150 tooth timing belt from an early 1.8T 20v engine, legos man, simply legos
