16v pistons. were to buy?
- Spoolin!
- Vehicles: subi's and vdubs
well we have decided to bore out the 1.8 16v for the rabbit, so the search for some new pistons has began. I've looked in a few placed but cant find them for the 1.8. we are lookin to go .40 over. maybe more. who knows.
any ideas?
any ideas?
Techtonics has them. $650.00!! ouch! That is why I have not ordered yet...
http://www.techtonicstuning.com/showpar ... um=107.819
I am sure JE and also Weisco makes them, but not any cheaper.....
http://www.jepistons.com/cat/je/sport/vw/16v.shtml
http://www.wiseco.com/PDFs/Catalogs/SC07/Volkswagen.pdf
Yup, you can do that, or you can start searching for some cheap piston sets. You can find them out there. My buddy in Seattle found some for $85.00!! Brand new 2.0 16V pistons, rings, pins and clips in the set and less than $100!! Just start searching.......littlewhitebeast wrote:ok.... does anyone have some semi low milage 2.0 pistons? Jamie at Advanced said i should look for use 2.0 pistons and just bore out the 1.8
2.0 16V Short block?? Are there rotating parts in it, or is it just the block? I am specifically looking for pistons and 92.8mm crankshaft. If this is the case, LMK, I want it. Dibs!PoorHouse wrote: so my 2.0 short block is available.
PoorHouse
- Back seat driver...
- Vehicles: 78 Rabbit
Includes rotating assembly.
All the external stuff has been removed, block was cleaned and painted. Didn't touch the internals.
The only pisser is a broken waterpump bolt. It left a couple threads sticking out though.
One other note: I cleaned up the pistons with the softest scuff pad. The first one I got a little aggressive with and rolled the edge of one of the valve relief cut outs. Shouldn't be an issue, but want to disclose everything.
What are you looking to get for it? And what color did you paint it? (cause this is really going to make or break the deal.....
To the best of your knowledge, this one has a 92.8MM crankshaft in it?
