ABS
ABS
well have been searching for a ABS problem thread on here but no luck ohh well lol. but my problme is i have had my ABS an Break light (blinking off an on) for some time now
when i looked up what i can it said a possibilty was the rear speed sensors so i got VW ones an repaced both sides an no luck.
the other thing they said it was also was the ABS unit ya i looked up the prise on that an all i had to sit down.
I am wondering if there is something i am missing so i get fix an get ride of the lights i realy dont have a problem not haveing ABS but the light are a lil anoing after a while. the brakes all work an all. when it gets pretty cold the lights go off an the ABS works
but
when it stays warm the lights will stay on an no ABS. ohh with these lights on i have no VSA which isnt a bad thing lol but tires are a bit prisey after a while lol but i dont have a problem there. so if any one has any ideas or answers would be helpfull thank you!
Re: ABS
no vag- com here. unless there is some one in g funk that dont know that has one....i have a mac code reader an A OBD2 notebook code reader which has a fue extreas but nothing that goes in that area
Re: ABS
Codes? Post em if you have them.
Re: ABS
i cant pull any codes i have nothing that goes in to the ABS area. everything i have wont read it. as soon as i get some codes or so ill post them tho
Re: ABS
Ah I see, well post em up when you get them.
Re: ABS
i see lots of problems with the ABS module/abs block under the hood, if you need to order one, its best to have the part nmber from the one on the car for reference.
