195/65/15 Studded I-Pikes on steelies
Classifieds category for wheels and tires
PoorHouse
Vehicles: 78 Rabbit
Post by PoorHouse »
Hankook Winter I-Pike studded snows 195/65/15 on black 5 hole unilug steelies.
Used these for less than one season on our old Volvo V70.
Asking $275 obo will consider trades for MK1 stuff.
Re: 195/65/15 Studded I-Pikes on steelies
What bolt pattern and offset?
PoorHouse
Vehicles: 78 Rabbit
Post by PoorHouse »
5x100 & 5x108 et in the high 30's.
Your audi is 5x112?
Yup, bummer cause I need a winter setup with tires.
PoorHouse
Vehicles: 78 Rabbit
Post by PoorHouse »
Make an offer on the tires only, I'll throw the wheels in for free.
You can trade the wheels for another set or for the mount and balance.
I need them out of the garage.
Not to torpedo, but Mike, will your brakes clear 15" wheels?
PoorHouse
Vehicles: 78 Rabbit
Post by PoorHouse »
Good point on the brakes.
BTW - I'm an idiot, just tried the wheels on the Wife's Subi which is 5x100 and they do not fit, both the patterns are to big. The Volvo was on the smaller set at 5x108, so the larger set should be 5x112.
Yup 15" will probably not clear the brakes. I suppose I need to find a set of 16" - 17" I can slap some winters on, but thanks for the offer on just the tires. Good luck with the sale :thumbsup:
Might want to verify the size on the wheels, cause I thought I had measured 5x112 on mine, but I think they are 5x114 cause they don't fit. :( Hence the reason I asked about yours for sale.
PoorHouse
Vehicles: 78 Rabbit
Post by PoorHouse »
Measuring bolt patterns to within a mm or 2 is tough when you are eyeballing the hole center. :screwy:
If you already have a set within 2 mm's you could get wobble bolts to fit.
Yes, tough it is for sure. Well, I suppose I could try wobbles, but I would need to get some hub rings to go with the wheels then. I've never run them, and have read +/- things through interweb forums. Cheaper than a new set of wheels for sure. I have a couple of Q's on the bolts, but I'm not gonna jack your thread, so I'll start another topic. :thumbsup: to you sir.
