I had one go out on Sat. and had to use it (I should have bought those spares from you JR!
Also a bit of weirdness...I got back in and tried to start it and it just cranked over but wouldn't start. So I Vag'd it and got:
17072/P0688/001672 - ECM Power Relay Load Circuit: (J271): Open Circuit
Which tells me a fuse or something power/connection related. I did some research and found that fuse #29 for engine management and ECU power was the culprit. I have no idea why it did this, but was glad it was an easy fix. So FYI to anyone else with this code to check fuse #29 - it's a yellow 20 amp.
