Removing a MK3 trunk badge
- Darkside
- Vehicles: 97' Jetta VR6
On the jetta, I read to use a heat gun and dental floss. I tried that but, the floss seemed to break a lot. I found that if you use kite string it cuts off the old 3m like butter.
Then you can paint it up or replace it. Hope that tip saves you some time.
Re: Removing a MK3 trunk badge
Pics? Did you remove or save?
- Darkside
I painted the badge black and put it back on. Euro badge look at no cost.
pic is in my thread in Members rides.
I did this also, but I was really lazy about it. I waited untill someone rear-ended the Jetta, then I instructed the body shop to not put the emblems back on the new trunk. SImple and effective. Total time, 3 seconds.
yeah so easy I should do it again and make a DIY out of it......wait, maybe not.
That is definatly a unique way to do a modification on your car.
- BooglesMcGee
- n00b...
The adhesive on mine had gotten so bad that I just pulled them off with my fingernails lol. Then used some 3m adhesive remover to get the leftover adhesive off.
nice, almost a 3 year bump
- BooglesMcGee
- n00b...
I'm a necromancer
