02a linkage
02a linkage
I would assume this is the root to my transmission/linkage problem. Any suggestions on where this needs to be positioned? I really have no perception of how the position of this component relates to the shifter.... I think I need a second set of hands.
Re: 02a linkage
Well that part adjust for the side to side alignment of the shifter. The bolt should not be loose. If it is, and wont tighten up, you need a new one.
You want to adjust it so 3rd and 4th are directly up and down.
Wanna compare it to my Jetta?
