Partin out 1987 GTI 16V
Yeah, that may be a possibility, I will look into it. Bozeman, right?
Next GTG I will be there. If you can give me a list of the stuff that you need, i will pull it off for you and bring it over. The more detailed the better. Sorry I didn't make the GTG last weekend, but I had some friends come into town, and you know how that goes...
no harm no foul, okay list here, i dont want to shoot the value of 1 good and one bad recaro so let me know what i can have and what i cant
1. airbox, complete with fuel diz and lines to injector.
2. injectors
3. hmmmmm.... im brain fartin
4. are you going to use the stock ECU??
2. injectors
So far that all sound kosher to me.
Are you needing just the ECU, or do you need wiring harness also? I would assume that if you have a donor motor, you shouldn't need it, but let me know. Also if you think of anything else, just LMK.
If you can tell me what that would have come out of, I can tell you.kompressorgolf wrote:would you happen to have a 1.8 digifant 1 ECU/?
its a 91 golf GL with the 1.8 8v RV engine code, couldnt find the problem with it, pulled the plug of the ecu and it was packed full of corrosion, so i took it out to clean the grounds and what not, decided to break it open, and there is a big nasty brown burnt center on the ecu..... nasty, no way that car was going to run
both of my ecus are out of 16V cars. If you are going to use a 16 ecu and harness, that might work for you.
