German AWD
- Darkside
- Vehicles: 97' Jetta VR6
Re: German AWD
not the ending I was expecting....reminds me of one of my projects. haha
Re: German AWD
Me either.Darkside wrote:not the ending I was expecting....reminds me of one of my projects. haha
Take 2
- Darkside
Re: German AWD
I don't know what your day job is but, you do some quality work. Nice fix on the wire
Re: German AWD
I was not as successful in AZ as I'd hoped but I did get some needed bits.
I'll call these speed mods.
First the trunk tools
Before
After
The tool Kit
Before
After
Then some interior trim bits
Before
After
Before
After
The little pieces really complete a project for me so they're important.
Before
After
The tool Kit
Before
After
Before
After
Before
After
Re: German AWD
I understand.......kevin286 wrote:The little pieces really complete a project for me so they're important.
Re: German AWD
I had some issues with my power steering brackets so I picked a replacement set up when I was down in AZ.
You can see on the top the bent bracket. Turns out I was missing that dog leg too. No wonder it didn't fit right
Got them switched out and the pump lines up now much better.
Also got a lower splash guard. Turns out these are an IX specific part and I got one off a regular IS so..
This one was starting to show some wear
And a crack
So
Glassed. Not perfect, it just goes on the bottom of the car..
To be replaced at some point in time with a proper skid plate
After coating with some truck bed stuff
So the IX part I'm thinking is shaped different, longer on the bottom, shorter on the sides.. I trimmed this to fit so it'd hold my brake duct things in place till I can find the correct piece.
Driver side was missing the stud, so I had to put one in
Here it is installed.
And you can see how it holds in the vertical piece that's the rear socket for the brake duct
And a crack
So
- Darkside
Re: German AWD
looks good! I have a set of black BMW sun visors if you happen to need those PM me
Re: German AWD
Giggity
Re: German AWD
<excuses style="tone:whine;"></excuses>
Pulled the car in the garage
On the list is to replace:
Engine Support
To get to the inner ball joint nut, you hit it from the top of the engine. I don't have a long extension so made do with this. Ha, ghetto I know, but it did the job.
Got the tie rod ends broke loose, and the subframe loosened. I can't get the outer ball joints off so I'm at a stand still. Going to hit up Don's and see if he has a tool for this.
This is the tool I need. HF but.. I don't want to wait. Napa can get one but.. same wait.
- Steering Rack
- Control arms
- Rear control arm bushings (m3)
- PS Steering lines (if needed, I can't tell if they are leaking or not)
- Steering shaft guibo.
Engine Support
