it said not to add extra sealer and that it has a coating already, so didn't use copper coat like on single layer metal gaskets, should have got a comedic gsk, owe well!Roadhog wrote:should have put some copper spray on the head gasket.
twin charged 16v Scirocco ( car is for sale)
- autoboost-tech
- In the engine bay...
- Vehicles: 81 Scirocco S 16v turbo/supercharged
Re: twin charged 16v Scirocco (new motor)
Ya, without it you will blow your manifold welds.Roadhog wrote:should have put some copper spray on the head gasket.
/threadjack
- autoboost-tech
manifold welds where tri-criptoflux dilated with a subatomic cripta-nano modulatorMikeWire wrote:Ya, without it you will blow your manifold welds.Roadhog wrote:should have put some copper spray on the head gasket.![]()
/threadjack
also had the pistons skids fused with the con-rod charging springs
have to do the cam brakes later
- autoboost-tech
here's a couple update pix from when I was taking a break, then it's back to work, wha.....who...
PS: I also drilled and pined the crank nose today that took a lot of time, but worth it!
cool angle to see both blowers
slurp system
getting closer
the nut behind the seen
OK I am back to work, later!
slurp system
getting closer
Damn I love this build!!!
Thanks for the update pictures!
- autoboost-tech
she's real close, might start it up here real soon, cranked over fine to get oil up top end, and all sounds great! and good compression, still need to put the rad in and coolant and rap up some stuff under the car, so hopefully I will be driving it tomorrow, but now I need to get plates and tabs, the wash tabs expired last month,
I don't know why I get nervous every time I rebuild a motor when about to start it, but I do! for years and years, god knows how many motors, I can't count them, I hate this part
- autoboost-tech
OK.... all on top is done, cooling system finished, defiantly will rap up tomorrow and run the motor, I just ran out of steam tonight!
Nice work! A trip to Bozeman tomorrow on the 2 lane roads would be a good break in for that motor
- Vehicles: 01 s4
i cant wait to see a video!!!!
2003 RS 6
2011 Ford f-150 ecoboost
2003 RS 6
Re: twin charged 16v Scirocco (on the road again)
That looks sweet man. Break her in easy.
