WTB 86 Jetta 4 door drivers door glass
76scirocco
Post by 76scirocco »
I need a drivers door glass for an 86 Jetta 4 door. Give me a shout if you have anything.
Thanks
vrtpassat
Re: 86 Jetta 4 door drivers door glass
Post by vrtpassat »
[quote="76scirocco"]I need a drivers door glass for an 86 Jetta 4 door. Give me a shout if you have anything.
Thanks[/ when do you need it i no were on is :thumbsup:
I should have one of those in my storage unit. I parted out an 88 a while back. You need the small window version?
76scirocco
Yes, I need the small window. I could also use the regulator if you have it. Let me know how much you want.
I will check, but the window was out of a a GLI, and it had power windows. I might have a manual reg out of an 87 GTI, though. Now , when you say small window, are you using that as a body style reference, or do you actually need the small front quarter window. I was assuming you needed the main roll-down window.
76scirocco
I need the roll down window itself, the smaller style with the quarter window. It is a GLI with power windows also, the regulator track is kinda messed up. I need the window for sure, power regulator if you have it.
Randy, if Aeron doesn't have what need, you may check A-1 - I saw a couple older MKII and MKIII out there that may work, although I don't know about power regulators.
DieGTi
In the engine bay...
Post by DieGTi »
The mk2 at a1 is a 1990 4dr jetta gl with manual windows. All 4 doors would need some body work; the rear drivers door was in a light impact and probably couldn't be used. There were no other mk2s there as of today.
jettastyle420
Re: WTB 86 Jetta 4 door drivers door glass
Post by jettastyle420 »
Did you find what you were looking for? If not i have all that for ya. Lemme know :)
76scirocco
I found one. Lockwood auto had one, they just had the car listed as the wrong year in their computer.
