FS: high comp built 1.8 8v
Posted: Jun Tue 03, 2008 9:45 pm
decided to sell the built 8v, i've got alot of time and $ into this motor.
$400, comes with everything pictured, with or without 4spd trans (no charge) prefer to sell local, dont want to ship
specs:
ported and polished big valve solid lifter JH head
decked (unsure of how much)
less then 10k on the head
RD 10:1 compression bottom end
less then 50K on bottom end (no lip at the tops of the the cylinder bore)
comes with port matched intake ported for big TB
unverifiable specs (PO did some work)
over sized valves
amount decked
compression ratio is estimated at around 10.5:1
specs:
over sized valves
amount decked
