1994 Golf 2.0
- mk2dubber
Re: 1994 Golf 2.0
I don't think its the hall though, cause it will pop that code out even when it isn't running. I emailed a dude with a VAG Com scanner in Wheatland WY so i'll probably go get it scanned after holidays.
Re: 1994 Golf 2.0
it won't run at all with a bad hall sensor.
Re: 1994 Golf 2.0
So, in conclusion, scan the car with it running.
Re: 1994 Golf 2.0
Yeah pretty much, unless you ignore those codes.MikeWire wrote:So, in conclusion, scan the car with it running.![]()
- mk2dubber
Re: 1994 Golf 2.0
Well that is the thing, i can only flash the codes when the car is off (i dont have a VAG scan tool) so thats not gonna work.. otherwise i would scan it while running haha.
- vrtpassat
Re: 1994 Golf 2.0
i got nothing have tryed some things on a 2.0 in the shop just to try and find you some help all i can think of is a cracked ditributer cap
sorry i can not spell
if it was that then whance the engine warmed up a little the engine would start to run ruff just a thought and i no some one ells kknows what i am talking about
- mk2dubber
Re: 1994 Golf 2.0
Ok, i know what you are sayin. Kinda like cold it contracts and warm it expands? i'll look into that.
- vrtpassat
Re: 1994 Golf 2.0
yesmk2dubber wrote:Ok, i know what you are sayin. Kinda like cold it contracts and warm it expands? i'll look into that.
Re: 1994 Golf 2.0
Rotor and cap should cost less than $15. It would be worth that just for piece of mind. You might also look into the "Tune Up Kit":
http://www.germanautoparts.com/Volkswag ... trical/275
- mk2dubber
Re: 1994 Golf 2.0
I'll pass on the tune up kit =] i custom made a set of MSD 8mm wires and i got a set of bosch plugs. But i'll be gettin a cap and rotor once im back in wyoming.
