Did some more work on the GTI today....
Battery tray delete....
Still have to smooth things out and fill holes but I primered it so da rust stays away!
Started grinding out what rust I did find in the window frame....
I also noticed that since I pulled the doors and such that the bare metal roll cage has started surface rusting so I figured i'd start to prep it for paint and decide what color I wanted to paint it. Just etch priming it here....
Got the rear windows out with help from Josh as well! Thanks a ton Josh! Literally took like 1 minute per side to pop out! Thanks for the advice Stoney and Kevin on getting those suckers outta there.!
I also got the rear hatch off and pulled the rear tails out along with the last of the wiring harness for them.....
All the glass out and finally getting to barebones body....
Good glass all around other than windshield. I'd like to track down a defrosterless rear.
Pulled the headliner out in mint shape......
I painted the one part of the cage a metallic gunmetal grey. I think I am going to stick with that for the cage and paint the rest possibly tomorrow. What do you guys think of that color?
I still don't know about the rear apron yet. It's pretty far from straight but I honestly don't know if I am up for putting a new one in. It looks like a ton of work!
The rear inside is clean as could be though!!!
Test fitting the MKII dash......
I am going to have to do some cutting of the original brackets for this to slide in all the way but the actual dash is already modded for a MKI. Thanks again Aeron for sourcing that baby out for me!
And as always I finish my update with "as it sits" right now in the garage!
I
