1992 GTI R32 VR6 project...
- Leifro
- Vehicles: 80'VrCaddy
83TCQ-85S1
90Corrado-83GTI - Location: H-Town Montana
Re: 1992 GTI R32 VR6 project...
But really mike. I have a few choices in transmissions for u. I do have also a CCM code from corrado, couple from the generic mk3 vr, I have your subframes, shift box and maybe any wiring u also might need. I do believe t he subframe is corrado vr
- SweaterVest
- Vehicles: 97' VW GTI VR6
So that 16v has been spoken for? I might be picking up a b4 VR6 that got hit in the rear for a parts car if you're interested in that
Yep - great little truck, resurrected from the dead. Little rusty but not too serious. Great patina. I need to get rid of one project, this would be a good addition to your stash, and I could haul it up to you if you want.Leifro wrote:A blue caddy? I've got tons of parts !!
viewtopic.php?f=79&t=3117
- Leifro
83TCQ-85S1
I would have a "truck full" of parts upon your arrival. A caddy certainly pertains the value of such stashed parts. I'll go though your list and check off everything I can for ya
- Leifro
83TCQ-85S1
I'm definitely interested in the rear hit pass not there wes
Yeah, Randy wants it back, plus the trans and wiring. He has plans for it all. I'll take whatever you guys have that will work.SweaterVest wrote:So that 16v has been spoken for? I might be picking up a b4 VR6 that got hit in the rear for a parts car if you're interested in that
- SweaterVest
Dang I was thinking that might be sweet in my new mk1
- Leifro
83TCQ-85S1
Parts on parts on parts
- Leifro
83TCQ-85S1
New mk1?SweaterVest wrote:Dang I was thinking that might be sweet in my new mk1
- Leifro
83TCQ-85S1
MikeWire wrote:
Parts needed:
If there's something I need to add or change, please chime in.
- Cosmetics:
- Driver side door card, handle and window crank
- Passenger side mirror
- Hood release cable
- Ebrake handle/assembly
- Interior mirror trip cap
- Exterior passengers side trim, just in front of door on fender
- Glove box...I have blue brown and also black
Motor:- VR6 MKIII Subframe...vr corrado front vr passat rear
- VR6 downpipe/header w/ O2's if possible...from 24v...perfect for mk2 swaps(via mt getto)
- VR6 exhaust...many bits and pieces perfect for custom jobby
Fuel:
MKIII VR6 fuel tank and pump...in tank mk3 including lines from tank to motor
Transmission:- VR6 transmission - 02A and clutch assembly
- Eurowise trans adapter -*** http://eurowise.com/shop/index.php?main ... cts_id=336
- VR6 Shift box and cables for VR6 trans
*** also check eurowise for their manual clutch cable kit for the o2a. It's what I run in my mk1. Less mess and installs flawlessly. An +A score for such seemingly tacky solutions
Axles: (wanting to keep 4 lug)- For 02A trans - 100mm...got em.
Cluster:- B3 Passat Speedo Cable (mechanical cable) and also a vr6 corrado cluster
Steering:- leifro also had the correct ps lines and fluid jugs!
