Now for a MK4.
Re: Now for a MK4.
Ya about the seats. They are from a passat and are 1" to wide in the track. So it was back in with the stockers. But to answer your question yes I have the controllers. And it would have been as simple as running a few wires.
- 201motels
- Vehicles: 2003 CL500
Re: Now for a MK4.
Are the taillights smoked with film or spray? I've been thinking about doing the film on my A6.
Re: Now for a MK4.
It's night-shade and way to dark. I'm going to try to remove it. I did however use night-shade on my A6 and it turned out pretty good. But in time it sun fades. I would go with a film.
Re: Now for a MK4.
laquer thinner works great to strip it off, did it tonight! twice! the lense will need a polish when it comes off tho.
- 201motels
Re: Now for a MK4.
I herd that if you use nightshades you should hit them with a coat of clear to keep them from fading and also make them shiny.
Re: Now for a MK4.
i tried to clear the set i did the other night, and it made it like matte finish. looked cool as hell, but the light coming through wasnt enough
Re: Now for a MK4.
So when I purchase the Jetta I noticed that it was missing one of the bolts on the upper intake. I also noticed that the car at idle the car had a surge. So I started looking for vacuum leaks. Well wouldn't you know it the upper intake was actually missing 3 of the five bolts. The middle front bolt and both of the bolts on the back side under the intake. So I figured that I better take care of it. While I had the intake pulled I changed plugs and gave it an oil change. Cole you will be happy to know no more purple people eater.
- paintballguy424
- Vehicles: 2009 Tacoma TRD Off Road
69 Beetle - Location: Laurel, MT
Re: Now for a MK4.
The purple manifold made its way to your rabbit right!?!?
Re: Now for a MK4.
Ya not so much. :DJust painted it black.
Re: Now for a MK4.
So got the new rubber in today. Turns out that two of the wheels are tweaked pretty bad. The crappy thing is they look real good on the car. Well time to do some surfing the web to see if I can find a matching pair.
