Ahhh you beat me to it!!t53a wrote:you should store your crank on end. other wise it will warp laying down![]()
StaggeredMK4's MKI GTI Teardown & Build Thread......
So how much of a rebuild or you doing? Rering, deglaze, bearings? or are you boring over?
Ground up rebuild. All the details will be released further down the road as I start ordering stuff! Imma add a lil mustard to her though!MikeWire wrote:So how much of a rebuild or you doing? Rering, deglaze, bearings? or are you boring over?
I do however have some updates!!
I hate pulling interior crap out! I was being as careful as I could with the dash as it's pretty much mint and would like to find a new home for it.
Here is the interior before starting......
And so it begins.......
I hate pulling dashboards!
The AC assembly that someone had added aftermarket
Got all the heater and AC crap out.....
Both seats out and all the non-firewall wiring removed.....
It still amazed me how rust free this 25 year old car is!! I
Effin nasty crap under the rear floorboard carpet!!
Carpet finally out, both front floorboards are dented up a bit from previous owners not knowing where/how to use a floorjack on a VW
Still no rust yet though!
As she sits tonight after the interior delete
looks good! BUt if you hate taking interior stuff out, you are going toreally like putting a MK2 dash in!! ALso that stucky stuff under the carpet is teh suk! I have that dash for you, you can come get it tonight before I head to the lake if you would like.
MK2 swaps isnt that bad, i got it down to an art if the mounts are the right ones, and it looks like his arent... so it might take a little longer. that sucks the roll cage is welded in instead of bolted bases....is it staying in? and working around it?
Yeah i'd like to pick it up tonight. I don't get off work till 6. What time you leaving for the lake?Rennwagen1 wrote:looks good! BUt if you hate taking interior stuff out, you are going toreally like putting a MK2 dash in!! ALso that stucky stuff under the carpet is teh suk! I have that dash for you, you can come get it tonight before I head to the lake if you would like.
I won't mind putting the MK2 dash in even if it's a pain because it's a upgrade.
Roll cage is welded in and I really don't have alot to do to the rear anyways so I won't mind working around it. This is not going to be a show car by any means so I am not too worried about the ass end.kompressorgolf wrote:MK2 swaps isnt that bad, i got it down to an art if the mounts are the right ones, and it looks like his arent... so it might take a little longer. that sucks the roll cage is welded in instead of bolted bases....is it staying in? and working around it?
