I assume he found out the powers of boost. ahahMT-Getto wrote:Just got a phone call asking if I have a spare rabbit axle, cause one just got shattered............
okay new rabbit new build thread.......
Re: okay new rabbit new build thread.......
- Spoolin!
- Vehicles: subi's and vdubs
LOL! i havnt had a single cv let go yet..
dont you have that ff in the rabbit bdub? i might have a spare 90mm axle if you didnt get it sorted already
I provided the hook up
I think ima need more.... car pulls very hard holds a steady 4.80 lbs boost. which isnt shit really. but the power that few pounds gives is pretty incredible.
yo rats, you gotta put a 16v head on your motor, 12 PSI on 8 valves, = 5 psi with 16 valves its rediculous,
- Spoolin!
i need obd1 aba block for my spare valver head... that still needs at least 8 valves.. thats kinda the plan for rocco thou. that will be turbo prolly digi1 lol
dont forget your rabbit weights at least 600lbs less then the jetta.. 2460 is what i weight in at with an empty tank.. and me not in it.
ill have to get mah tranny swapped out and make it down one of these weekends
or you can come up for a helena gtg
Mine weighs exactly 2000 with me and a full tank
literally 2000.00 AND ounces. guy at the scale said he'd never seen one 0 out on the scale. on another note, i was having trouble with the car, it was idleing at 300 0 power down low, i tried everything the timing looked spot on, i fixed a small vac leak (injector cup) as the vac it idles was around -14.1 instead of -21.4 like normal, i made sure the ECU was clean checked the coil pack turns out. i broke out the hub on the crank pulley. the t-belt stayed normal, while the outside of the pulley (with the timing magnets) was twisted back over a half inch retarding the timing over twenty degrees
all the rave about how quick it was in the last post, was with 20 degrees too much timing
Oh yeah and Cara
- ValveFloat
- Vehicles: 1991 911
- Mrbubblehead
- In the passengers seat...
nice
you can see the further that she got pulled back into the chair the bigger the smile got.
