1991 Audi 200 20VT
vegas2017
- Vehicles: 01 s4
Re: 1991 Audi 200 20VT
nice! well the block in that is pretty much indestructible. if you havent changed the plugs, oil, filters, etc....do that then look for any vaccum hoses that may need to be replaced. a boost leak will take the fun right outta you, they suck but are usually cheap and easy. i gotta intake pressure tester if you need it. all youll need is a compressor that you can adjust the air on. let me know and congrats!
2003 RS 6
2011 Ford f-150 ecoboost
2003 RS 6
Changed the spark plugs and the oil and oil filter. I need to change the air intake and that should take care of the filters. I need to change the timing belt also, well figure out how to do that.
1991 Audi 200 20VT
What did you use for plugs oil and filter?
Mahle filter, NGk plugs and Casterol synthentic.
I need to figure out this door pull cable, can't find it anywhere
Coupe Quattro wrote:Mahle filter, NGk plugs and Casterol synthentic.
Put the cluster back in!
Guess what, all the displays still work!! Only bad thing it the Airbag light is constantly on and the break light, oh well nothig I can't deal with.
Clock is a little messed up, well I take that back a lot messed up. This thing has 2 bars that show out of the whole square.
Also began putting the car back together, driver seat is in but the rest is still floating around in the cabin.
I need to find a door pull cable and a door handle the driver one is broken and I need to get out haha.
Well I hope more progress soon!
Also scared the shit out of myself when I connected the battery back up after putting the cluster back in. Well I kinda tightned the screws a little to tight, while in the garage the horn went CRAZY. I don't think I have turned a car off that fast ever
Ordered the needed parts today and later tonight there will be a few changes done to her
vegas2017
- Vehicles: 01 s4
Nice! keep up the good work!
2003 RS 6
2003 RS 6
Parts on, well all but the bumper cause it doesn't like to fit... but progress pictures soon!
vegas2017
- Vehicles: 01 s4
i know what you mean, even the guys that fixed my front bumper couldnt get it to fit right.....me and john have some work to do.
2003 RS 6
2003 RS 6
