Interesting topic for a build thread
Re: Interesting topic for a build thread
Justin, at least you got the right color combo for Bozeman. Go Bobcats!
- bmx_a4
- Vehicles: 00 A4 Quattro 1.8T
98 A4 2.8 - RIP - Location: Shithole, WY
haha right?Ramrod wrote:Justin, at least you got the right color combo for Bozeman. Go Bobcats!
So I decided to go through and check all my bell housing and starter bolts, because my car does not like to let those bolts stay tight. To the point that my car was down for a couple days in Bozeman because I completely lost a starter bolt.
Well, sure enough, I had one starter bolt that had backed all the way out, and two loose bell housing bolts. Apparently a $20 bottle of loctite isn't enough for 8 bolts. FML.
2000 A4 1.8TQM -
- bmx_a4
Alright guys, priorities have shifted so I'm selling the Audi. I need to get the beast gone.
Friends, I am selling my car!
FOR SALE :
2000 Audi A4 Quattro 1.8T
~132,000 miles (Will rise slightly, since I drive it daily)
The Good :
- Single mass flywheel
- New clutch (Valeo unit, came as a kit with the flywheel)
- Rear main has been replaced
- Valve cover gasket replace
- Spark plugs changed
- Timing belt was done in January
- APR Turbo inlet Pipe
- APR Snub mount
- New turbo (stock unit)
- NewSouth Performance column mounted Boost/Vac gauge
(Less than 1,000 miles on all those parts)
- DDW Slim ballast 55w 8000k HID kit
- Cat-Back exhaust (Not sure on the size but it's at least 2.75")
- Eibach Sport springs (1.2-1.75" drop)
The bad :
Hood is damaged from a hit and run
Windshield is cracked (Does not obstruct view)
Wheel bearing needs replaced (Bearing is included with car)
For the right price I'll include an S4 front bumper, rebuilt cylinder head with head gasket and whatever miscellaneous other parts I have for it.
Low private party value is ~$4,400 (low value given due to body damage)
FOR SALE :
The Good :
- APR Snub mount
The bad :
2000 A4 1.8TQM -
