2001 Allroad Rehab
Discussion forum for Audi A5/A6/S6/A8/S8 and Allroad
Re: 2001 Allroad Rehab
i have a rear diff too if its the same style. thats really wierd. i hate working on auto's it always seems to be something. Kudos to guys that rebuild auto trans for a living....
Allroad diffs look the same but without the long snout, not sure if you could swap the snout from the allroad diff and run it.
kompressorgolf wrote:Allroad diffs look the same but without the long snout, not sure if you could swap the snout from the allroad diff and run it.
Do you have the front axles?
I'm doing some research now to find out what the possibility would be.
dont have the axles
Bummer. But at the same time it will also will be an awesome swap.
Sent from my iPad using Tapatalk
Ok, I'm calling it.
Failed trans, so this is now going to be 6MT swapped.
If anyone knows of a local C5 A6 6 speed, I need a parts car and/or drive line and swap bits.
Alternatively, I'm looking at this kit. This decision is based off of quite a bit of feedback from Audizine users, plus i called Scott, the owner, and did a sniff check and he seems to know exactly what he's doing over there:
http://advancedautomotion.com/shop/prod ... cts_id/312
check audis4parts.com they have full allroad swaps as well.
and it says they do the rebuild on them before they go out. just put one of their kits in an s4 and came with everything needed minus one bolt.... a starter bolt.
kompressorgolf wrote:check audis4parts.com they have full allroad swaps as well.
For sure, I checked them both and found better feedback with AA. Really good feeling that both places have good Audi parts for just about all platforms :thumbsup:
AA is awesome too, bought my 6mt rebuild kit from there, best prices and service, Think his name was Scott Dewitt? they have a really good harness for the reverse lights. and an adapter to make the auto trans driveshaft work with the manual, nice billet piece.
