Sweet. Thanks. I might be able to get a deal through one of our customers, but not sure. I'll keep looking for tires. Let me know if you find anything in a 17 inch.padro04 wrote:I shall do that for you !!!! lol 17s are big but i got 18s for my wagon lol so i guess you can say i go the distance lol
I did make a bit more headway on the e28 today:
Completed the rear bumper lipo. Basically, I unbolted the bumper, which is held on by three bumper shocks that were necessary to meet US DOT regulations at the time. Drilled out three holes each, used the trailer hitch of my Land Cruiser and a floor jack and managed to compress them about an inch and change. Bolted the bumper back up and it's a great improvement! When I finally get some tires, I'll use the ol' brick wall trick and see if I can't get it to compress a bit more.
As most of can attest, when you dive in a project, there's always more you find to do. I found some ...
When the 5er was on the road, it bounced around a bit and didn't handle all that well. I figured it was the tires. Turns out one of the rear shocks is totally blown. I found shock oil all over the trailing arm and suspension assemblies. Most of the springs are showing some corrosion. Sooo... I'll need shock and springs. My thoughts are the package available from Bavarian Auto - Bilstein Sports and the Bav Auto springs. It should give a great ride and lower the car about an inch.
The new battery has since been drained. So either with the doors open, changing the handles drained it. Or there's a short somewhere. So there's that.
I also ordered up some stainless steel brake lines in a moment of weakness. Those should get here this week. I"ll put some new brake fluid in, as well. Probably DOT 4 Motul.
Also, I cleaned the replacement grills. If this warm weather keeps up, I'll shoot 'em with some black rattle can. One side is pretty faded, so they need just a bit of freshening up.
