MikeWire - My garage...
Re: MikeWire - My garage...
awwwwwsheeeeeeiiittt!!!
They look really good. So he does good work?
- autoboost-tech
- In the engine bay...
- Vehicles: 81 Scirocco S 16v turbo/supercharged
whats powder coating cost these days for four rims? I had a leaking rear caliper I just noticed last week and it ruined the coating on one rim, I think it just leaked from having the e brake on to tight and to long, seem to quit with it off, couldn't find a rebuild kit with a gasket for the e arm so will have to replace whole caliperBig Montana wrote:They look really good. So he does good work?
usually bout 50 a wheel here in bozeman, they were that when matt had his Zender sports done. did good work to!
It was $375 for all four of mine but I had them dismount/mount/balance the tires, new stems, and touch up a bit of rash before the PC.
Kompressorgolfs PC was really done well, but if you want to take a trip to Billings check out http://powderkoteunlimited.com/ - ask for CW and tell him you talked to me.
- autoboost-tech
thanks! defiantly doable at that price, I was thinking maybe red to match the interior, need to fix some curb rash on one as well, unless! can they do that too?MikeWire wrote:It was $375 for all four of mine but I had them dismount/mount/balance the tires, new stems, and touch up a bit of rash before the PC.
Yup he can do it as long as it's not too bad - I think he just smooths it out and doesn't use putty, cause regular bondo doesn't like 350F. You could do it too, just use a bit of spot putty (just use something compatible with powder coating) and go easy with a fine grit paper until it's smooth, PC and it will look good.
You know you want to.
yeah, a nice textured flat red on that Bomb intake would contrast super well!
