StaggeredMK4's MKI GTI Teardown & Build Thread......
- vrtpassat
Re: Veedubya's MKI GTI Teardown & Build Thread......
if you would every anser your phone or give me a call i would be more than happy to help you bud with your car
Damn, so just got off the phone with Josh at TT to order the dist cap for the ABA block, all he had were a couple of used ones and he wanted $40 bucks. OUCH.
I need it though so I ordered it.
John, if you'd get your own phone i'd know who was calling and answer, instead you call me from strange numbers that I DON'T answer! lol
- 73veedubya
- In the passengers seat...
- Vehicles: Mk4 Jetta GLS TDI
73 Superbeetle - Location: Missoula, MT
no remeber in Highschool when you had to ask. Is John there? and they usually say well i dont know whos calling?
Hey Brandon,
What SDS system are you running?
EM-4D?
EM-4D?
EM4-F the works
and very simple indeed. takes out alot of guess work.
You are still running a dist and not coil packs right? Any advantage to the coil packs vs dist?
- 73veedubya
you wont have to change the points and roter with teh coil pack
. but that would concern alot more electrical work
- Checkers
No, B-dub is running coil packs.
Re: StaggeredMK4's MKI GTI Teardown & Build Thread......
the coilpack system doesnt really involve much more wiring, and even then its simple as shit. coilpacks are the way to go, that way the whole system is self contained. they are good coils too, you can run boost way into the 20's before you need an MSD booster added in. with a distributor, to adjust timing, you gotta loosen the two ten mil bolts turn the dizzy and hit it with a timing light. with coil packs, you hold the timing light in one hand, the SDS controller in the other push a button and watch it work. too easy trust this!
