I have a VAG-COM in Missoula now.
I flash the Touareg's ass all the time!!
Yeah, no problem. I usually leave the laptop at home, and usually after work wrks best for me. I could do it tonight (tues) or thursday or friday. Let me know what you want to do. you can give me a call at 544-8258, and we can work something out. Bring a sixer of Kokanee or Cold Smoke and we will call it even!
Hey, I too would like to hook up. Can I keep my headlights from turning on as soon as the ignition is on and ebrake are let off? My headlights are on all the time and would rather just city lights lit unless I turn my headlight switch on?Rennwagen1 wrote:Yeah, no problem. I usually leave the laptop at home, and usually after work wrks best for me. I could do it tonight (tues) or thursday or friday. Let me know what you want to do. you can give me a call at 544-8258, and we can work something out. Bring a sixer of Kokanee or Cold Smoke and we will call it even!
Thanks man
Jason
yeah, that is probably possible. Check for the coding on the vortex in the Mk4 forums and see what you find. You may even find other stuff that you want to do to it also.!
G60, I am not too familar with the corrado plugins, does it have the standard OBDII connector under the dash?
No, it has a 2x2 connector under the shift boot, you will need a special adapter to read the codes. Even then you will only get basic codes.Rennwagen1 wrote: G60, I am not too familar with the corrado plugins, does it have the standard OBDII connector under the dash?
Edit: on the G60's i'm pretty sure the only codes you can pull are the abs codes from that connector. G60's aren't OBD as far as I know.
Ah, I don't have the 2x2 connector, so we maybe screwed in that case. I have the Hex+Can connector.
