Now for a MK4.
Re: Now for a MK4.
Thanks Brandon. I have the fender and bumper. I pulled them to get some misc. things squared away. It still needs a bunch of tlc. I also got a couple of bolts left and the tranny will be out for new seals and VR flywheel and clutch. Thanks to Mike for hooking me up with the VR flywheel.
Re: Now for a MK4.
So the tranny is out of the car. Well lets just say that it's not just a bad seal. ImageImage
Not sure what went wrong inside but I drove it home doing 75mph with no issues and it shifted fine.
Re: Now for a MK4.
JB stick weld.
Re: Now for a MK4.
I would but I'm guessing something let loose inside. Who knows how long it would last.
Re: Now for a MK4.
Vtec kicked in Yo.
Ah, just patch it up and run it, it'll be fine.
Re: Now for a MK4.
I may just go with my other 02j and then take the broken one in for welding. My only concern with that is they both have different shift linkages. But I may be able to swap them out. I have never welded aluminum before so I wouldn't feel comfortable doing it myself.
Re: Now for a MK4.
Good find, but needs more purple manifold!
benno3231
Re: Now for a MK4.
Post by benno3231 »
Looks like you and I are in the same boat. I picked up a 99 gls vr6 same color for 200 this summer! Just about to finish up timing chains and misc. vr cooling leaks. Good luck, lets have a cheap jetta contest!
Re: Now for a MK4.
This is definitely going to be extreme low budget build.
Re: Now for a MK4.
that sucks to find! hoep domethign plops in your lap
