RADO IS BLOWING UP! PLZ HELP!
- DrewG60
- Vehicles: 1990 VW Corrado G60
Re: RADO IS BLOWING UP! PLZ HELP!
Also, the engine is remaining cold for some reason. Just another piece of info for the equation
a great man once said..."F**K a HONDA!" oh wait, that was me...
- DrewG60
Thermostat perhaps?
- DrewG60
15w50....heh...who knew?
???DrewG60 wrote:15w50....heh...who knew?
- vrtpassat
is this what the gage is telling you or have you felt the engine it might be for this problem a bad sending unit gage is messed up or broke wire unless you have a fail safe termast in wich when they fail they fail in the open position as to not over heat the engineDrewG60 wrote:Also, the engine is remaining cold for some reason. Just another piece of info for the equation
good luck i wish i could help more but you are a ways away
sound like a normal week for a corrado, though, huh?!
LOL EVERY 28 DAYS LOL.... i think the samething now an then lol
- DrewG60
it was the gauge...due to coolant leak... found and fixed. everything is now fixed except for oil leak. its very small as I am not losing a noticeable amount of oil however *from a novice's perspective* it appears to be dripping on the header which makes for a nice plume of smoke.vrtpassat wrote:is this what the gage is telling you or have you felt the engine it might be for this problem a bad sending unit gage is messed up or broke wire unless you have a fail safe termast in wich when they fail they fail in the open position as to not over heat the engineDrewG60 wrote:Also, the engine is remaining cold for some reason. Just another piece of info for the equation
And then a fire.DrewG60 wrote: it appears to be dripping on the header which makes for a nice plume of smoke.
- DrewG60
a fire???? you must be joking....how can i fix this?Roadhog wrote:And then a fire.DrewG60 wrote: it appears to be dripping on the header which makes for a nice plume of smoke.
