Really Poor Gas Mileage
choncho
In the engine bay...
Vehicles: jettas n a 3/4ton
Re: Really Poor Gas Mileage
Post by choncho »
yeh, i agree w the wind theory. i did bozeman to sheridan (thru billings) last fall in the 2.0. did about 10 trips and gas mileage went from 25-35. all from differences in wind. and some days i couldn't really feel the wind in the car or pedal and my mileage was loooooow.. my rack could use a fairing for sure
i can agree on the wind my lil kia had the same problem when i would go frm great falls to dickinson. an thats pretty flat so i am a hill in the middle of a desert it seems like if you have lots of stuff up here that kills you in the end. when i took the wagon with out anthing on to i got better then when i i had some thing on top on the rack. but who knows it wuoldnt hurt to check all the other stuff an finish up on the tune up.
The wind definatley plays a part. I was lucky this time it really wasn't blowing.
an how was the gas milage hopefully better?
Here's your scan Matt:
Tuesday,09,March,2010,13:14:00:10253
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 9M - VW Jetta IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 228560km/142020miles
Address 01: Engine Labels: 021-906-018-AFP.lbl
Part No: 021 906 018 S
Component: MOTRONIC ME7.1 G 6761
Coding: 00033
Shop #: WSC 07228
2 Faults Found:
17559 - Long Term Fuel Trim Additive Air; Bank 1; Range 1: System too Lean
P1151 - 35-10 - - - Intermittent
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction
P0135 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 JS
Component: AG4 Getriebe 01M 4834
Coding: 00000
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 01317 785 00200
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 03 AIRBAG VW6 0202 0004
Coding: 12339
Shop #: WSC 01317
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 905 K
Component: A4-KOMBIINSTR. VDO V09
Coding: 07232
Shop #: WSC 01317
Part No: IMMO
Component: IDENTNR: VWZ7Z0A3396236
IMMO-IDENTNR: VWZ7Z0A3396236
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00007
Shop #: WSC 01317
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 8Y Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 01317
Part No: 1J1959801C
Component: 8Y Tõrsteuerger. FS0002r
Part No: 1J1959802D
Component: 8Y Tõrsteuerger. BF0002r
Part No: 1J4959811C
Component: 8Y Tõrsteuerger. HL0002r
Part No: 1J4959812C
Component: 13 Tõrsteuerger. HR0002H
3 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
End ---------------------------------------------------------------------
So it needs an O2....
Darkside wrote:So it needs an O2....
Yup...pre cat heated sensor. Luckily it's not too badly overpriced and can be found at oreilly auto parts - OE version even.
My, newer VR (97) with over 180k returned 29.5 MPG on a trip to helena and back recently, and that was with a faulty throttle body.
That is almost exactly what mine gets!
Why does mine get 26mpg at best?
