my 8V gk2 needs help!!!
Re: my 8V gk2 needs help!!!
well i've finally found some dollars and the work has begun. most of the mechanical things seem to be working properly and now its just down to tracking down the damn electrical problems
... in the meantime i need to get it drivable and was wondering if anyone knew where i would get a headlight/ radiator rack, or whatever its called. cuz mine has kinda rusted away and i need to get the radiator firmly attached so its not flyin around anymore.
Its called the core support. germanautoparts.com has nearly anything you will need
ill be in the garage tonight if you want to stop by again.
ok long time no work done but its on this weekend... everything drivers seat forward is coming out and going into boxes. i'd like to grind out a little of the rust in htere and prime/ paint it. then we'll go from there.
Sweet mk2 , Stoney ( checkers) and the rest of the bozo boys will take great care of you. good luck
harnesses, and tubing have been taken out just have to dissconect the tranny and pull hte engine
oh and do i need to take the bumper off??
it will be easier. Just remember that the front bumper bolts keep the front cross member in, so you need to support the front of the engine. This is for both the MK2 and MK3
- Jd3
- Silky Johnson
- Vehicles: emgay4 sixbangr
good call trev... that shit is a toe/hand/face buster if you dont support the engine and your not expecting it
Only need that to happen once to learn.
or not at all
thanks
thanks
