Scirocco F street prepared engine options????
if you really want i would still sell the built 1.8 i have.... its in a car atm but i could pull it for ya... should still be in the clasifieds :thumbsup:
link:
http://forums.bigskyvw.com/viewtopic.php?t=1095
I'll give you them both man. Come get 'em!
76scirocco
Post by 76scirocco »
Checkers wrote:I'll give you them both man. Come get 'em!
I will try to get up there for them in the next week or two, thanks
76scirocco
t53a wrote:if you really want i would still sell the built 1.8 i have.... its in a car atm but i could pull it for ya... should still be in the clasifieds :thumbsup:
link:
I just spent a chunk of cash, so I can't do it right now. When I get some cash built back up I will give you a shout to see if its still available.
76scirocco
It's a holiday so your probably not around, but if any day this weekend would work I could run up and grab those motors
Thanks
I'm around all day Sunday at work but I've working three blocks away and I can come home whenever man!
76scirocco
Send me your number and I'll call you when I get to town on Sunday
Thanks
I B GOLFIN
Post by I B GOLFIN »
that 1.6 is really harshing my gig in the garage. come a get it.
76scirocco
Re: Scirocco F street prepared engine options????
I have been putting in a lot of hours in the shop the last couple months to get ready for this week. I had shoulder surgery this week to fix some problems caused by stupidity of my youth so it will be a couple months until I am back to work. I am still on some potent pain killers, so I appologize if I don't make a lot of sense.
I purchased the engine from a 92 cabriolet in order to build my scirocco to fit the FSP SCCA class. I know there are lots of more powerful options out there, but I did not want to be thrown into XP with this car. I am building it to the allowed overbore. I have the machine shop tightening up some clearances, shaving the head, and working on balancing. I have sent the intake off to be extrude honed. I pulled the 190mm clutch setup out of my old 1.6 setup to keep things light. I have a 9A close ratio trans with Quaiffe diff installed. I also put in a .75 overdrive to help with rpm down the highway.
I am going to run it on DIGI II for the first year, but plan on eventually giving Megasquirt a try. I am going to try the TT chip for this setup along with an adjustable fuel pressure regulator.
I have the suspension dialed in pretty well. I am just adding some more chassis stiffening and a beefier front sway bar to try to reduce the rear tire lift. It is already polyeurethaned with Bilsetein sport struts and shocks. The springs are somthing from the past, but seem to have fairly aggressive rates.
I am stealing the Recaros from my GTI for this car. I do not plan to do much on the paint and body until the engine is sorted out. I am going to strip it for paint only when I feel it is nearly mechanically comlete.
Now it is the waiting game of waiting for the machine shop to get me my parts back and my shoulder to heal in time to install everything.
Was wondering where you were, hadn't heard much from you. Sounds like a cool project, you should post some pics up of the build.
Shoulders are the worst, I had mine fixed too, it sucks! Luckily it will work better after :)
