YASHA GTI build.
- Jd3
- Silky Johnson
- Vehicles: emgay4 sixbangr
Re: YASHA GTI build.
just thinkin about this and how it probably relates to your car..... when i was scraping the underside of mine, i was a little over zealous and ground all the rubber drain plugs from the frame. I would either save a couple to grab part numbers off of, or source now and grind the shaz out of them... updated pics!!!!
they wont be available from vw anymore, ask me how i know
just be careful around them, they will have been protected pretty well by the undersealant just remove the old and reinstall later!
Just a heads up I am still looking for a rear seat for the MK1GTi. So if anyone knows were I could find one let me know. Thanks
76scirocco
- Back seat driver...
Would it be the same as a Scirocco? Are you looking for a certain color or are you planning to recover it?
Scirocco seats work great in rabbits!
I have the stock GTi seats so I think I am just going to recover them and try to find a back seat.
76scirocco
If you are going to recover it to match, I think I have one for you.
Yes, I am going to do recovers. Let me know. I also still need the suspension bolts for the front control arms and rear carrier. Also the shifter mount plate for the floor. Let me know what you dig up. Thanks
Just found out that I am getting a new set of door panels for the MK1 GTi for my birthday. SWEEEEETTTTTT.
